Author Topic: Electric fans  (Read 8503 times)
Re: Electric fans
« Reply #30 on: June 16, 2018, 10:17:34 PM »
Alright, here's my issue. Maybe y'all can chime in with some suggestions.
This would have been the lower mounts but I had to narrow it to fit.
My idea was to use these rubber bumpers but barely have room for the stud to point up (cutting it down quite a bit).
Plan B, was to have the stud go through the bottom and grind it down a bit.
What do you all think ???
BTW it's a walker model A for Chevy engine radiator.
« Last Edit: June 16, 2018, 10:19:17 PM by Rattiac »
Re: Electric fans
« Reply #31 on: June 16, 2018, 10:50:22 PM »
Rattiac, I confuse easy ;)    Is this what you were thinking?
Sorry, i have the shakes tonight.
« Last Edit: June 16, 2018, 11:11:24 PM by sammons »
Re: Electric fans
« Reply #32 on: June 16, 2018, 11:11:03 PM »
Yes, exactly.
Re: Electric fans
« Reply #33 on: June 16, 2018, 11:18:54 PM »
I would rather mount it solid to the radiator strap/suround(?) If room allowed, (bolt up) close to 1/4" clearance should be fine. Leave just enough bolt to get it above the nylock nut. Make sure put some locktite thread locker on also. Down fall there is nut back off and rub a hole in tank, (but slim chance)
Mounting it bolt down would probably be fine, but I always worry about rubbing a hole in bottom of bracket from dancing around. Again probably unlikey.
« Last Edit: June 16, 2018, 11:39:59 PM by sammons »
Re: Electric fans
« Reply #34 on: June 17, 2018, 12:03:47 PM »
Ended up pointing the stud down. Wasn't gonna fit pointing up.
Re: Electric fans
« Reply #35 on: June 17, 2018, 12:54:52 PM »
That illustration is very PICASOESQUE...........to the right one seems better choice of mounting.
Re: Electric fans
« Reply #36 on: June 18, 2018, 12:08:30 AM »
Well, the car is back together (minus hood) and managed to warm it up but.... couldn't get the fan to run.
No power to the (Gray) electric fan wire. Checking the fuse box and that was good.
Walked away after that.  >:(
Re: Electric fans
« Reply #37 on: June 18, 2018, 09:49:00 AM »
Well, Fatnlow said he sent the Grimlens packing....maybe they moved out your way ;D
Re: Electric fans
« Reply #38 on: June 18, 2018, 11:03:22 AM »
Using a relay? If so, no power until the relay is grounded via temperature sending (or manual switch).
Re: Electric fans
« Reply #39 on: June 18, 2018, 02:28:10 PM »
Speedway said I need to check behind the fuse box for the no power issue and I'll have to wire up a relay.
For some reason I thought it had a relay already wired in the kit but I guess not.
Words cannot describe how much I hate relays. The car is grounded for a month OR at least until I feel like working on it.  >:(
Re: Electric fans
« Reply #40 on: June 18, 2018, 07:33:02 PM »
Wish I felt like working on mine   Just to blame hot   where'd did spring go :(
Re: Electric fans
« Reply #41 on: June 18, 2018, 10:34:41 PM »
Sent the Gremlins packing...got my problems lined out.....been working  just in the morning hours ...getting hot here...
Re: Electric fans
« Reply #42 on: June 18, 2018, 10:57:51 PM »
Here is a basic single speed fan set up...ignore the indicator light and toggle switch wiring (unless you want them)
Re: Electric fans
« Reply #43 on: June 18, 2018, 11:10:24 PM »
Here it is without toggle/light.
Re: Electric fans
« Reply #44 on: June 19, 2018, 11:44:14 PM »
Was able to check it out tonight. There's power at the fuse box and...... I was pretty sure it was already wired with a relay (correct me if im wrong)
. Just no power at the end of the fan wire.
OK im stumped. Here's some pics.
(Upper right I had the relay pulled)
