Author Topic: 1926 buick roadster  (Read 306920 times)
Re: 1926 buick roadster
« Reply #180 on: December 08, 2014, 07:03:59 PM »
You're alright chopper. After all you drive and built a chevrolet 8).
 I was racking my brain on how to get the fender to line up with the 32 chevy splash aprons, when finally I decided to work the fender instead of the apron. I cut a few slits in the lower fender edges that need body work anyway, and then I pulled and clamped the two together. Now all I have to do is add about 11 inches to the length of the apron. The custom running boards will be easy.
« Reply #181 on: December 08, 2014, 07:18:55 PM »
Anybody that builds Chevrolets is alright,
« Reply #182 on: December 08, 2014, 08:16:28 PM »
Come on Chopper even I can tell the difference between a Moose and a Goat. Oh sorry I meant Ghost. ::)
Ghost it is really looking good. It was designed to be a big car just keep the proportions and it will be fine. I really like the lines of the hood and the radiator shell.
« Reply #183 on: December 08, 2014, 08:55:02 PM »
Awesome, Ghost. Almost like it came that way!
« Reply #184 on: December 08, 2014, 09:01:33 PM »
Ghost   I've looked at the third picture three times now and the only issue I see is the curve or rounded part of the apron which shouldn't be a problem. If you slice the curve can you pull it to the fender?
« Reply #185 on: December 09, 2014, 12:39:47 AM »
« Reply #186 on: December 09, 2014, 09:00:55 AM »
Yeah that is an issue I haven't worked on yet.  I will probably make the curve in the fender to match the splash apron.
« Reply #187 on: December 09, 2014, 09:06:59 AM »
Sixball thanks the measurements are exact for my grille. Gonna have to keep an eye on this one. I don't see a reserve.
« Last Edit: December 11, 2014, 09:26:00 AM by ghost28 »
« Reply #188 on: December 09, 2014, 10:11:38 AM »
Looks like you're getting it spliced together just fine ghost.
Sixball, man that winterfront is cool! I've been wondering if the heaters in these cars worked worth a darn in the winter. I guess I'll be changing out thermostats spring/fall. I would like to have something similar for mine.
« Reply #189 on: December 09, 2014, 02:01:07 PM »
When you look at that fender and apron I think that curve is a small, no big deal fix compared to what you have done.
I put that winterfront in my watch list, I have never seen anything like that before. Of course when I first got my car I had never seen a swamp cooler either. :) I'm a'learnin'.
« Reply #190 on: December 09, 2014, 02:04:23 PM »
A really nice NOS one for a '30 or so Chevy sold about week ago for over $200 if I remember correctly. Essex & Hudson had adjustable louvers stock. They didn't have water pumps like "Ts" but I have read it worked pretty well with a big radiator and a 4 blade fan. We'll see if I get the rest of the stuff to put an Essex together. ::) Anyway Ghost, I'm glad it interested you and I hope you get it. It would add an even more "Unique" look to your roadster. 8) There can't be a lot of those out there.
« Reply #191 on: December 11, 2014, 09:34:01 AM »
I think I have gotten a cold and it's slowed me down, but I have gotten the running boards extended and screwed to the rear fenders for fitting.  I  have a question for all of you. On the hood I was thinking of making it a one piece top, but I can get a new stainless piano hinge for it also. Leather straps would hold it down both ways.
One piece, or hinge it????
« Reply #192 on: December 11, 2014, 09:54:24 AM »
Ghost, I think if you are using the hood sides (I assume you are) you need to hinge the top. Otherwise you won't be able to open the hood, you would only be able to pull the hood side out. The sides just sort of flapping out to the side. It would look cool but you would have to take the whole hood off to access most of the engine.
 If it is just for looks: one piece top. For practicality: two piece top. Just my 5 cents.(Two cents isn't worth what it used to be) ;D
« Reply #193 on: December 11, 2014, 11:32:57 AM »
I won't be using the hood sides.
« Reply #194 on: December 11, 2014, 12:04:54 PM »
Ghost I would agree with chopper if you were using the sides. But just the top half, I like the smooth look and would tend to weld up for a one piece. That's just a personal preference though ;)
