Author Topic: 1926 buick roadster  (Read 172412 times)
Re: 1926 buick roadster
« Reply #135 on: November 25, 2014, 07:39:33 PM »
As I said before welding ang grinding over and over. I have most of it finished for awhile. So I decided to do a preliminary bend of the 1/2 inch thin wall electrical pipe for the rag top. It bent for the most part OK, but it does kink pretty easy if you are not careful, and the area I chose to work on has more compound curves than Dolly. I will probably do another one like this since I have a copy to work off. The rest of them are gonna be easy. Famous last words.
« Last Edit: November 25, 2014, 07:41:49 PM by ghost28 »
« Reply #136 on: November 25, 2014, 07:45:15 PM »
That looks real good, Ghost. If the tubing is covered with canvas the kinks won't matter too much will it? If so, would a heavier gauge tubing be too heavy?
« Reply #137 on: November 25, 2014, 07:50:04 PM »
Thanks. You are right the canvas would wrap around each piece kinda like a old style headliner does over the bows. I think if it was any heavier I would have to heat it before each bend, and this guage hold the shape real good once bent, so this will have to work.
« Reply #138 on: November 25, 2014, 08:17:07 PM »
Wow John you're really on a roll!  Keep it going looks great.
« Reply #139 on: November 25, 2014, 08:22:26 PM »
Thanks Tom. After looking at the stock height top design against the chopped version in these two pictures. I think I am gonna lower the windshield and top a little bit to make it a little more of a hot rod. What do you guys think?
« Reply #140 on: November 25, 2014, 08:28:11 PM »
I do like the bottom one.  I think giving it a little trim would give it that "Hot Rod" look.  Just leave yourself some head room!
« Reply #141 on: November 25, 2014, 08:32:48 PM »
Comparing the two pictures you posted lowering the top changes the looks considerably, I like it.
« Reply #142 on: November 26, 2014, 05:04:53 PM »
Well comparing the pictures helped a little, but I decided to bend some  tubing for above the door to check if I would like it and with the stock height windshield the side opening was large, so I took the windshield post off and marked 3 inches with some tape. TOO LATE NOW, but it does look a lot better once I tilted the visor up so I could see. I will post some pictures a bit later of what I have done.
« Reply #143 on: November 26, 2014, 05:08:37 PM »
John,
If you need any measurements off of my car for comparison let me know.
« Reply #144 on: November 26, 2014, 05:12:50 PM »
John,
Thanks wiil do. This boat is so different than everything else, I am guessing and measuring about a million times.
« Reply #145 on: November 26, 2014, 10:34:30 PM »
here are a few pictures of the tubing as it is now for the top and the 3 inch chop I did on the windshield frame. I decided that the top won't fold, but it will be removable with a couple of bolt downs which I probably wont do anyway, I like my shade. I am gonna make some removable side windows out of the original frames.
« Last Edit: November 26, 2014, 10:37:34 PM by ghost28 »
« Reply #146 on: November 26, 2014, 10:51:23 PM »
3"chop looks good on that windshield frame ghost. I've built a lot of CJ tops out of 1/2" conduit, despite people telling me it wouldn't hold up, it holds up just fine with a bend or two. Looks like you got plenty of work to do this weekend.
« Reply #147 on: November 26, 2014, 10:55:34 PM »
[/quote] Thanks. I am trying to think of all the things I wont do after I get it on the road. So yeah lots to do. I guess you are gonna spend some time over the holidays in the shop. HUH?
« Reply #148 on: November 26, 2014, 11:00:10 PM »
That thinking part is a pain in the a$$. Every time I think I have figured out all I want, I remember something else I forgot.     Yep, I am way behind schedule.  Spring will be here  before I know it. :)
« Reply #149 on: November 26, 2014, 11:13:58 PM »
It's deceiving because of the rise in the center of the cowl.  Looks great though.
