What diameter tire are you running ?Cherokee's come with 3:55's (Chrysler 8.25 axle)If it'll fit width wise.Gear changes are so expensive that I found a axle with the ratio I wanted.
Quote from: Rattiac on April 09, 2017, 05:38:23 PMWhat diameter tire are you running ?Cherokee's come with 3:55's (Chrysler 8.25 axle)If it'll fit width wise.Gear changes are so expensive that I found a axle with the ratio I wanted.p255 R70 15 about 28.5" tall
I got mine from a 2WD Chevy S10. Width from wheel mounting surface to the other is 54.5" The 4WD S10's are 59".
As I posted the other day that I was going to take the 32 out for a good long drive today. I have a stock 350 motor with a TH350c transmission and a rear end with 2:41 gears, Fuel mileage was not so good something needs to change. Any suggestions?
