Author Topic: Anyone know hydraulics (ie tilt trailers etc)  (Read 1319 times)
« on: January 24, 2017, 05:45:02 PM »
Looking to fabricate a light duty flat bed dump on my 3500HD 135.5 WB cab chassis.  The bed will be 7.5 wide and 9.5 long with wood deck (don’t want a metal deck this time around).
I have a heavy duty scissors hoist that I removed from a 3500HD dump truck (pic attached), don’t want to use it because it just takes up too much space and the height would require a higher bed surface.
Prefer to use a single cylinder:
Tie Rod Cylinder
3.5X24
Shaft 1.5”
Retracted 34.25
Extended 58.25
From my rough estimates (ground lay out) I should be able to easily obtain a 45 degree angle - plenty for my hobby farm needs.  I understand that the scissors lift technically lifts the bed whereas the single cylinder actually pushes it up which is harder on the bed hinges and hydraulics…but I can’t locate a small scissors hoist.
Questions:
How big of a hydraulic oil tank is need for a full extension of the 3.5X24 cylinder, will be using it as a single function cylinder (ie gravity down).
Will that cylinder be sufficient, it will have at least an 8” drop angle.
Re: Anyone know hydraulics (ie tilt trailers etc)
« Reply #1 on: January 24, 2017, 10:47:43 PM »
I don't know anything but I'll be watching this. I like to make the bed on my flat bed dump. It would be really handy. I just read that hydraulic winches tie into the steering pump. Probably not enough volume for this.
Chevs of the 40s Parts
Hamby Motors Vintage Parts SC
JULIANOS HOT ROD PARTS
TECH LINKS REFERENCE & MISC
DAVE's Small-Body HEIs
