Quote from: munch on January 03, 2017, 07:21:00 PMQuote from: 62131 on January 03, 2017, 05:15:11 PMWater in the oil is a concern, more of a hassle than creating a severe problem. Thinking about this a little more, I helped a buddy of mine put an Atomic EFI on his car. When we started it for the first time it had a high pitch sound, and it was the A/F ratio needed adjusted, as he made the adjustments you could hear the sound change. It sounded like a jet engine, I think this is what your hearing. I was just in the shop looking at the Fitech unit and there is a crack in the body which run down into one of the four ports. I will send a pic when I can.I haven't dropped the unit, but I don't know if they will believe that. Can't afford another one right now. If you had dropped the unit , it would clearly show where on the unit that the blow occurred.Question is why did the unit crack .Get your magnifying glass out and do a thorough inspection to see if you can determine the reason why.makes sense , doesn't it , before you try sending the unit back . mike
munch...do you feel that the crack was responsible for the noise?
