Author Topic: Wiring a MOPAR 3 wire alternator?  (Read 1918 times)
« on: October 22, 2016, 07:25:09 PM »
My buddy is wiring up his car and is using this 3 wire alternator, the ground and battery power is self explanatory. It has (2) field connectors, the one on the left has a ceramic insulator.
My question is which terminal gets the exciter wire and how is the other wire wired?
Does the MOPAR alternator have a built in diode for the exciter wire or should I solder one in?
Re: Wiring a MOPAR 3 wire alternator?
« Reply #1 on: October 22, 2016, 07:39:17 PM »
Maybe this will help.
« Reply #2 on: October 22, 2016, 07:53:25 PM »
Ghost beat me to it. Late 60's up till ?
« Reply #3 on: October 22, 2016, 08:12:16 PM »
Thanks guys...looking at the diagrams this alternator doesn't have an internal regulator because it has (2) field terminals?
« Reply #4 on: October 22, 2016, 08:45:47 PM »
Ed, I just looked up my '98 Dodge p.u. and it said the regulator is external, located in the PCM. I don't know any thing about these newer ones.
« Reply #5 on: October 22, 2016, 08:52:44 PM »
I think you are right and my buddy needs an external regulator...found this article about converting the (2) field wire unit into a (1)  field wire car.
https://www.hemmings.com/magazine/hmn/2008/12/Chrysler-Alternators/1735462.html
« Reply #6 on: October 22, 2016, 08:55:19 PM »
There was something on there about a stand alone quick set up for a Jeep (same) using an old 2plug regulator.
« Reply #7 on: October 22, 2016, 09:08:50 PM »
Found an old post on the HAMB where a guy was trying to wire up a MOPAR alternator, gave up and installed a GM one wire  ;D
