Author Topic: Help locating radiator hose  (Read 1813 times)
« on: February 05, 2016, 08:53:34 PM »
Just installed a TPI small block engine in my dually project and want to run a mechanical fan, have a temporary fan and hose for now. This is the 1994 cab I installed on a 1995 3500HD chassis - almost done - runs great.
What I need is a 1-1/4" inside diameter flex hose with a 90 degree bend on one end, the hose needs to be approx 29" long. Attached a picture of the hose style I need....been searching online and at my local Advance Auto rack...no luck yet.
Re: Help locating radiator hose
« Reply #1 on: February 05, 2016, 09:18:57 PM »
« Reply #2 on: February 05, 2016, 10:44:57 PM »
unless that ribbed one in the picture already had that bend , I say your going to have a straight one and bend it onto the rad inlet.
Or get metal tube and rubber hose of right inside and concoct a new one from pieces.
« Reply #3 on: February 05, 2016, 10:59:18 PM »
Did you try Moose's post?
http://rustybowtie.com/index.php?topic=84.msg350#msg350
Thanks Tom..completely forgot about the link..but that 90 degree bend is a feature that most charts don't list.
The one in my picture has a 1.5" ID and 20" length...they most likely make the one I need...will need to hit more auto shops. Here is the link to the one in the picture:
http://www.frsport.com/Vulco-Flex-II-Flexible-Coolant-Hose-W--90-Degree-Bend_p_29335.html?gclid=CLOh8p-f4soCFQJZhgodndkPVQ
