Author Topic: Window Channels  (Read 14533 times)
jckwsky
Window Channels
« on: January 27, 2016, 01:27:58 PM »
OK, have yet to post pictures of my Pontiac up yet, but I need some help locating some replacement pieces.  Particularly I am working on the windows right now, just the doors and side windows in the sedan, an I have these old worn out window channels/Fuzz.  I have a found a few places online, thanks to the links here that sell some replacements, but I am mostly curious about what it actually is and what I should replace it with.
Re: Window Channels
« Reply #1 on: January 27, 2016, 10:06:59 PM »
I would think that you could get those felt u channels from any glass shop that deals in auto glass
Re: Window Channels
« Reply #2 on: January 28, 2016, 07:51:34 AM »
If you search the internet for window channel there is several suppliers out there, I'm going with the ones from Haggan,  they are flexible and can be formed into almost a 90 degrees in the corners.
Re: Window Channels
« Reply #3 on: January 28, 2016, 10:38:39 AM »
the U channel felt stops the side windows from rattling. Also allows the windows to go up and down smoothly. It also is a semi seal against wind noise.
I think if you get a lynn steele rubber catalogue ( Denver NC ) or go online catalogue you will find a lot of the rubber replacement parts.  Its a Fisher built body just like a Chevrolet and all those small parts, door bumpers ect are available.. This would also include the windshield wind up rubber set.
mike lynch      8)
jckwsky
Re: Window Channels
« Reply #4 on: January 28, 2016, 10:52:01 AM »
I found some flexible window channels, from Yogi's, that look similar to what is coming out of the car.  I will give them a try.  For what the website was charging they will be an inexpensive test run.  Will post after I get them in and test them out.
logride
Re: Window Channels
« Reply #5 on: January 28, 2016, 12:10:58 PM »
I used Hagan Glass run channel  # 910-01930 from speedway motors.
It's flexible and worked great.
Re: Window Channels
« Reply #6 on: January 28, 2016, 03:03:09 PM »
Re: Window Channels
« Reply #7 on: January 29, 2016, 02:48:22 PM »
I never did contact Jan Bogert (sorry Jan), I used Hagan's U channel that I ordered from Yogi's. It worked GREAT!!
