Author Topic: 34 Master Help on how to attach hood sides.  (Read 11065 times)
75TH RANGER INF
  • Cars are my way of life.
    • Master-Tech Automotive
« on: November 16, 2015, 11:05:11 PM »
I just bought a 3 Piece Hood Set from Rootlieb. I also bought the Carolina Custom Side Mount Hinge and Latch Kit and Carolina Custom Aluminum Hood Braces.
I will have to modify the front edge of the hood to match the contour of the top edge of the Radiator/Grill Shell
Where I need help is on the lower side panels. I want to attach them in a way that you cannot see the hardware from the outside. I thought of welding some studs to the panels and putting some brackets for the studs to go through and use nuts to secure them on all 4 corners of each panel.
Anyone with other ideas would be greatly appreciated.
Thanks,
Duke
"Operation Bright Star" Don't Mess With The U.S.
Re: 34 Master Help on how to attach hood sides.
« Reply #1 on: November 17, 2015, 09:49:42 PM »
like to help you but I have a stock 4 piece hood
mike       8)
« Reply #2 on: November 18, 2015, 12:40:56 PM »
This might help you.  62131 is mounting his hood sides separately from the top part of the hood.
http://rustybowtie.com/index.php?topic=1070.105
« Reply #3 on: November 18, 2015, 07:03:08 PM »
 What I did on an old coupe. I welded two bolts to the bottom edge of the hood side and sharpened them to a dull point and drilled two holes in to the top edge of the frame for them to sit in, then I did put hidden bolts on the top side interior edge and bolted them through some L brackets I made.
« Last Edit: November 18, 2015, 10:40:51 PM by ghost28 »
75TH RANGER INF
« Reply #4 on: November 18, 2015, 10:25:29 PM »
Thanks for the replies. It seems I jumped the gun in asking about this because the owner of Carolina Custom told me the hinge kit I am buying from his has everything I need to attach the sides. The hood sides apparently have pins on the inside bottom and set into a slot in the brackets that come with the kit. At least that's how I understood him to say it.
Thanks again.
Duke
