Author Topic: FAQs for all you inline Stovebolt Six Guys  (Read 16791 times)
« on: January 24, 2013, 03:36:53 PM »
A lot of guys like to use the good old Stovebolt Six in their rides so I thought this information might be of helpful. Even if you don't have a inline 6 it's still a good history lesson. :)
Re: FAQs for all you inline Stovebolt Six Guys
« Reply #1 on: January 26, 2016, 07:07:26 PM »
Moose.Is there anyone amongst us that is running a six cylinder and running a 700 R-4 Auto Transmission This 250 that i am think of is a 1978 out of a NOVA  thanks  vette59jdwl
« Reply #2 on: January 27, 2016, 08:57:12 AM »
I don't know of anyone first hand that is running that combo but if you asking if it can be done the answer is yes. I've seen a number of threads on other sites where guys talk about doing it. Here's one example from someone who has done it....
I ran a 70 nova 250-6 in my 48 chevy coupe with a 700R4 trans, it was a 91 camaro trans and the torque converter bolted right up to the 250 flexplate with no problem. I used the Bowler torque converter lockup electronic controller which justs plugs into the trans connector and all you have to do is hook up twelve volts to it through the pedal switch which is included in the kit. The bowler gives you 10 seconds after the trans shifts into fourth gear before it locks up the converter which is nice for a 6 cyl.. I ran a 3:25 rear end which kept the eng at about 1900 rpm with the converter locked up and the six didn't like that rpm range, its runs better at 2100 to 2500 rpm. I also have a 74 nova 250 and it ran a 350 trans with 308 rear gears, which the engine likes that combo. I used my original column with original shift lever, but I had to make a detent plate at the end of the column so I could lock the lever in park and so I could lock out reverse. It would still be wise to put a neutral safety switch in the circuit to.
« Reply #3 on: January 27, 2016, 11:51:34 AM »
Thanks Moose  i will have to give it some more thought  but if i went auto the wife could drive  if (god forbid) anything happened to me.  vette59jdwl
« Reply #4 on: January 27, 2016, 02:45:41 PM »
Anything that will bolt up to a small block V8 with the two piece rear seal will bolt up to a 194-292 six to the 153 four. A couple of issues with internal vs external balance but otherwise bell housings, trannys, flywheel/flexplate have the same bolt patterns. Many internal parts interchange as well. Some 292s use 1/2" flywheel bolts. Earlier 6s are different but later auto trannys can be adapted.
