Author Topic: Recommend brake flaring took kit  (Read 4884 times)
« on: July 04, 2015, 03:49:20 PM »
Just about ready to invest in a brake line flaring kit, I see Eastwood has a new turret style and there are also hand held hydraulic kits.  Have the traditional split clamp style...but not real happy with the flares on occasion.
What are you guys using?
Re: Recommend brake flaring took kit
« Reply #1 on: July 04, 2015, 05:02:08 PM »
I also have the split metal brake flaring tool. I think a lot of the problem is that the tube cut is not smooth and causes cracking in the flair.
I was also looking at that EASTWOOD TOOL and its slick. Definitely a well engineered piece. Kinda of expensive for a one time use .
 The part I did not like is that you have to purchase the special dies for $90 extra, to do AN aircraft fittings.  For the kind of $$$ involved it should have been part of it .
Luckily I have a friend who has one and no doubt will lend it too me when the time comes.
mike lynch  8)
« Reply #2 on: July 04, 2015, 05:24:07 PM »
I'm using an old Blue-Point split bar tool also. I agree with Mike. My dad taught me to use a fine flat file to dress the cut prior to flaring, and not to torque down to much on the double flair. Of course today i'm sure the quality of the tubing comes into play.
I also looked at the Eastwood turret tool. Too spendy for me at this stage, (if I were 20 again, I sure would!)
« Reply #3 on: July 04, 2015, 07:20:02 PM »
I have the split bar tool too.  I found that by deburring the end with a countersink tool and the using scotch brite to clean the outside end I'm going to flare it works better.  But it is frustrating at times.  A better mouse trap would be welcome.
« Reply #4 on: July 04, 2015, 07:47:37 PM »
Try using the ni copp tubing, it flares much easier than the old steel line.
« Reply #5 on: July 05, 2015, 09:48:00 AM »
I remember reading one of the street rod magazine articles and the person writing it stressed that the cut end should be filed smooth in order to reduce the chance of the flare splitting or having a hairline scratch and leaking.
I agree with other poster that excessive tightening can cause problems too.  Sometimes we do not know our own strength , even tho its failing as we get older.
mike       8)
« Reply #6 on: July 06, 2015, 06:40:19 PM »
I don't have one, I borrowed one from AutoZone when it came time to do my coupe. I have to admit, I still have some seepage from one of the lines in the meetering block. I know in the very near future I am going to have to do them over, just for safety sake. That will probably be a good time to invest in a quality tool.
