Author Topic: Anyone have any pics of doors inside framing?  (Read 37773 times)
« on: January 22, 2013, 07:49:46 PM »
Moving to welding up my chopped 33 (5W) coupe doors and removed all of the goofy wood the previous owner tried to install. Anyone have any pics of doors with metal framing?...Just to get an idea where to begin. Need to leave room for glass/tracking..but would like the latch hardware installed so I  can "slam the doors shut"! ;D
thanks
Re: Anyone have any pics of doors inside framing?
« Reply #1 on: January 22, 2013, 07:56:41 PM »
I used 1" square tubing around the perimeter of the door. I pie-cut and bent it slightly as needed to follow the contour of the door. Then I tacked it to the door frame and welded up my pie cuts. Solid as a rock and I'm not done yet. I will post some pictures tomorrow.  Jim
« Reply #2 on: January 22, 2013, 08:11:25 PM »
I have a buddy that is building a 34 standard 3 window coupe. I have a few pics of what he has done. the man is a genius.  He has cut down his wing windows because he thought they were to large from the factory. I hope it helps.
« Reply #3 on: January 22, 2013, 08:18:56 PM »
Thanks ...very helpfull...even the door gap shots are helpful.
« Reply #4 on: January 22, 2013, 08:39:10 PM »
Ed...I don't know if you've seen these tech articles and they have nothing to do with you question on the doors but thought you might enjoy looking at these links
http://www.streetrodderweb.com/tech/0709sr_1933_chevy_coupe/viewall.html
http://www.streetrodderweb.com/tech/0710sr_choppin_a_chevy/
« Reply #5 on: January 22, 2013, 08:48:40 PM »
That's where I learned how to chop the rear window 1" on my 33.
« Reply #6 on: January 22, 2013, 08:54:44 PM »
HaHaHa......I figured you had most likely already snooped it out!!
« Reply #7 on: January 23, 2013, 06:24:11 PM »
A few more pictures.
john miller
« Reply #8 on: January 23, 2013, 06:36:44 PM »
Great pics.
All you guys that have done this before need to make some type of "tech" post on replacing wood for all us newbies. Maybe putting year and body style below each pic.
With all the experience on here I don't think it would take to long to have a pretty complete guide put together. I believe it might go a long way to making this "the site" to come to when searching on Chevy wood replacement.
Just a thought.
« Reply #9 on: January 23, 2013, 06:46:39 PM »
Great pics.
Just a thought.
That's a great idea. I know I have documented at least three builds with pictures.
« Reply #10 on: January 23, 2013, 07:22:24 PM »
Ghost
Thanks for the pic. I realized that I need to finish the door "chops" before framing the door itself.
Also...my door "outside arcs" were not aligning with the body BUT a few hits of my metal shrinker in the flat area of the jam where the locks bolt...got the doors looking great. Flat at the top and curved at the bottom.
Another problem I worked on today was raising the drivers door about 1/16" so the body lines (what ever they are called) were in line with cowl and qtr panel.  The hinges aren't adjustable so I had to remove material  from the hinge joint and placed stainless washers on the bottom to hold the door up...looks nice also.
« Reply #11 on: January 24, 2013, 01:56:11 PM »
No I realize just how bad I am at taking pictures! Anyway, after I tacked the doors closed I chopped the top and doors as one unit. Then I dropped the top down and tacked it and the doors back together. Then I took the doors off, removed all the wood and replaced the wood around the perimeter of the door with 1" square tubing. I am going to add more metal to strengthen the door a little more, but it is very sturdy just as it is.
woodremover
« Reply #12 on: January 30, 2013, 04:35:07 PM »
Here's a few pictures of mine vent windows removed ,power window's original door latches and handles 34 chev 5 window
« Reply #13 on: January 30, 2013, 04:51:47 PM »
Woodremover
Thanks for the pics...just starting that framing stage...this entire post is very helpful.
« Reply #14 on: January 31, 2013, 06:20:38 PM »
Don't know what you guys are paying for 3/4" square tubing, but just bought (2) 24' lengths (.083) for $13.50 a length.
« Last Edit: January 31, 2013, 06:24:10 PM by EDNY »
