Moose's Tech Corner
(Moderator:
Calculators for almost anything automotive
Topic: Calculators for almost anything automotive (Read 7378 times)
January 19, 2013, 04:33:08 PM »
Take a look at these online calculators offered by Wallace Racing. Some will come in handy and others are just fun to play with. Just click on any of the links to check them out.
performance racing calculators.
ET - HP Calculators
Convert ET To Today's Condition
1/4 Mile Stats Calculator
Another 1/4 Mile Stats Calculator
1/8th to 1/4 to 1/8th Conversion
1/8th Mile Stats to 1/4 Mile Stats
Calc 1/4 ET/MPH/Gear Ratio
Calc 1/8th ET/MPH/Gear Ratio
Compute ideal MPH and times at 60', 330', 660' and 1000'
Convert 1/4 Mile ET to 1/8th Mile ET Calculator
Convert 1/4 Mile MPH to 1/8th Mile MPH Calculator
Hp From 1/4 MPH,ET and Weight Calculator
HP from ET with HP Correction
HP from ET with HP Correction for 1/8th Mile
Hp From 1/8th MPH,ET and Weight Calculator
1/8th Mile ET From HP With HP Correction
1/4 Mile ET From HP With HP Correction
New ET from Weight Change
Convert Your ET to Sea-level MSA ET
New ET from Previous ET and Weather Conditions
RPM At Peak HP Calculator
HP Necessary For A Speed
Estimate 60 Foot Time From Quarter-Mile ET
MPH at the 60' clock
Estimate HP From 60 Foot Time ET
G Force from 60' Times
Braking HP Loss at Altitude Calculator
0 - 60 Calc
Calculate Distance Of Win From MOV
Calculate Distance Traveled Using MOV
Calculate HP To Go 1 MPH More
Altitude Correction Factors
Drag Race Simulator
CID - Engine Calculators
Cubic Inch Displacement Calculator
Balancer Timing Mark Calc
Compression Ratio
Dynamic Compression Ratio Calculator
Effective Compression Ratio
Boost Compression Ratio Calculator
Camshaft Calculator
Camshaft Intake Open/Close Calculator
Overlap Calculator
LSA and Overlap Calculator
HP Change From Compression Ratio Change
HP From Bore - Stroke
Piston Speed and Port Velocity
New Hp From Adding More Boost Calculator
Torque From Adding Nitromethane Calculator
Blower Pulley OD/UD Calculator
Blower Pulley OD/UD Chart
Horsepower - Torque Calc
Pressure Loss From Fuel Line Length
Max RPM Calculator
HP - TQ - RPM CALC
Calc Deck Height
Calc Block Deck Height
Calc Piston Pin Height
Calc Crank Journal Overlap
Calc Crank Angle Speed
Stroke Calculator
Rod Length Calc
Calc Piston Inertia
Calc HP to Run Oil Pump
Engine Parameter Calcs
Ram Air Scoop Calc
Jetting Calcs
Gears - RPM Calculators
Conversion Calculator
Driveshaft Speed Calculator
RPM Calculator
Rear Gear Ratio Calculator
MPH - Gear Ratio Calculator
Tire Diameter Calculator
Gear Ratio Difference Calculator
Gear/Tire Calculator
Gear Ratio Needed Calculator
RPM Drop From Shift Calc
RPM/MPH From Gear Ratio Calculator
Speedo Gear Calculator
Tire Height Calculator
Converter Slip Calculator
Brake Master Cyl Calculator
Head - Exhaust Calculators
Air/Fuel Ratio Converter
MEP Calculator
Crank Accelerator Calculator
Throttle Blade Diameter for Individual Runner Intake
Header Tube Length Calculator
Carb/TBI CFM Calculator
Engine Friction Calculator
Calc Valve Lift From New Rocker Ratio
Milling Heads Calculator
Choke Point Intake Ports Calculator
Finding Choke Point On Intake Ports Using RPM's
Discharge Coefficient Calculator
Mach Index Of Intake Port Calculator
Flow at RPM Calculator
Max RPM at Flow Calculator
Head Flow Ratio
Minimum CA Calculator
Average CSA Calculator (using port length)
D - Port Area Calculator
Limiting Port Velocity Calculator
FPS Calculator
Pitot Pressure to Feet Per Minute Calculator
Head Flow Area Under The Curve Calc
Intake Runner Calculators
Intake Runner Length
Convert Head Air Flow From One Depression To Another
Calc Head Air Flow for the HP Wanted
Calc HP from Head Air Flow
HP From Intake Valve Size
Exhaust Valve Calculator
Intake Valve Calculator
Intake Valve Lift Calculator
Header Calcs
Curtain Area Calc
Dyno Correction Factor Calculator
Weather Correction Calcs
Density Altitude, Grains of Water, etc.
Barometer Correction Calcs
Convert Barometer to Absolute Barometer
Air Density Index Calcs
Air Density Index,Density Altitude, Grains of Water, etc.
Calculate Engine Performance Coefficient
Re: Calculators for almost anything automotive
January 19, 2013, 05:50:41 PM »
WOW..that's a great reference..Thanks
January 19, 2013, 10:49:03 PM »
Lots of great tools. Thanks for all the technical post Moose!
Moose's Tech Corner
(Moderator:
