Author Topic: 1930 Chevrolet two door sedan  (Read 3814 times)
sedan1933
« on: March 07, 2015, 10:35:42 AM »
We have a 1930 2dr sedan for sale. A super straight rust free sedan body was purchased from Kansas. All parts were stripped, frame was boxed with a fatman front end and a s-10 rear installed with 4 link coil over springs and shocks. The frame was sprayed with epoxy primer and several coats of black paint. Rearend was completely rebuilt with new drums, brakes, spring kits, wheel cylinders, backing plates, and new brake lines and fittings. A new driveshaft was cut to length, balanced and installed with new universals. The engine is a 283 cubic inch Chevy that was professionally rebuilt with new .040 over pistons, balanced rotating assembly, performance valve job, new Edelbrock intake, 4bb carb and a performance hydraulic cam. For cooling a new copper radiator was specially made for this auto with 2 electric cooling fans.  Transmission is a GM turbo hydromatic 3 speed, rebuilt with a shift kit, all hooked to a stainless steel tilt steering column ad after market steering wheel. The rims are American Racing aluminum 10" wide rears and 8" wide fronts. Body has been chopped 2 inches and sports a new steel top insert and steel floor boards. All wood was removed and replaced with tubular steel. Electric windows were installed in the doors and sports a stainless steel exhaust. Car is painted with 2010 Camaro blue, base coat, clear coat, sanded down to 5000 grit paper and buffed. The interior was sent out and done by a lead upholstery shop in tweed. Car also sports a new array of dash gauges along with rechromed front and rear bumpers. Car is ready to be driven to a new home as it is inspected also, insured, and has been driven several hundred miles locally. This car is all steel with over $35,000 invested in parts and 3 years of labor. Asking $27,000 obo. You can call if you have any questions  My name is Ryan and number is 315 586 3138.
sedan1933
Re: 1930 Chevrolet two door sedan
« Reply #1 on: March 07, 2015, 11:12:07 AM »
some more pictures of the car. if you want more I will take some more and post them.
« Reply #2 on: March 07, 2015, 08:01:40 PM »
That's a nice looking sedan, and the color is great on there. Hoow long ago was it finished?
sedan1933
« Reply #3 on: March 08, 2015, 10:24:01 AM »
it was finished 2 years ago. drove it around last summer. I believe it has less than 1000 miles on it since built.
sedan1933
« Reply #4 on: May 04, 2015, 02:32:27 PM »
This car has been reduced to sell. The new price is $23,000. It would make someone a nice car. He just needs room for other projects. Thank you.
