Author Topic: 1933 Chevrolet 5w master coupe  (Read 7529 times)
sedan1933
« on: February 26, 2015, 11:29:27 AM »
We have for sale a 1933 5w master coupe with a steel coupe body, doors, dash, floor sections, grille and shell. The fenders, trunk lid, running boards, grille shell apron and rocker panels are all new fiberglass, some of which have some mounting holes drilled in them. One rear fender has had a section cut and removed. May have fiberglass to fix it. There is rust out at the very bottom of the rear inner fenders(quite easy to repair as they are straight flat areas), and right door at the very bottom to the rear. The rust out on the lower cowl sections was removed and used sections screwed in place. They just need to be welded in. All the wood needs to be replaced or metal put in place of wood. There are many pieces that can still be used for patterns if you choose to put wood back in. The package includes fender brackets, head light bars, and window guarnish moulding. The 1/4 window guarnish mouldings are too long and need to be shortened. There is a bad spot in grille but have extra piece to fix it. The frame and chassis is stock 1933. There are no trunk brackets but they are in the process of being cast up and will be available in the near future. Asking $8500 or best offer.
