Author Topic: Rear spring replacement  (Read 8535 times)
Re: Rear spring replacement
« Reply #30 on: January 23, 2015, 03:09:05 PM »
Ed,
Just in case you were interested I got a price of $505.95 for the Posie's kit with the shocks included.
Thanks Tom...contacted them..the shipping is $63.84
Looks like their springs are 1-3/4" wide (same as stock) but have the Teflon buttons.  I have enough parts here, including the parts I got from you to almost put my own kit together.  It's only the proper springs holding me up...but as mentioned I'm still in the planning stage on this stage.
« Reply #31 on: January 24, 2015, 08:43:50 PM »
Ed  Where i got my first idea was from You tube  go on you tube and type in 1932 chevy truck its some nimrod hillbilly up in the mountains and hes the one that got me onto the 1989 dodge d-50 rear  its narrower than the s10 the datsun and the toyota check out his episode on *41 driveline and driveshaft  good luke  wayner
« Last Edit: January 25, 2015, 03:40:36 PM by vette59jdwl »
« Reply #32 on: January 27, 2015, 02:18:11 PM »
Looks like the 74-91 Ramcharger front springs are what has been used in the past. They are 48" long and bolted together right in the middle at the 24" mark, 2-1/2" wide, arch 1-3/8" with 3 leaves.
Looking at the slider option vs the standard shackle option I found the following guidelines on Speedway Motors.  What I learned was that mounting the forward eye(s) inboard may improve handling?
Here is a link..the second last paragraph discusses it:
http://static.speedwaymotors.com/images/charts/Slider_Tech.gif
