1933 Chevy Cabriolet
19
20
21
Topic: 1933 Chevy Cabriolet (Read 135814 times)
Re: 1933 Chevy Cabriolet
Reply #285 on:
May 24, 2016, 05:14:07 PM »
Yes it looks really nice, they did a real nice job
Reply #286 on:
May 28, 2016, 01:00:47 PM »
A couple more shots of the grill. Got the headlight bars on this morning. The reflection is awesome.
Reply #287 on:
May 28, 2016, 01:10:13 PM »
Now to finish up the work on the shroud. The bottom was trimmed to clear the lower part of the fan. Then in the third and fourth picture a flange was welded to the frame of the radiator and rivet nuts were added. Then four button head cap screws per side can hold the shroud in place.
Reply #288 on:
May 28, 2016, 01:15:19 PM »
Here it is bolted to the radiator. Then I drilled a hole and added the grille emblem for a 32 Chevy. Then I cleaned it up and mounted it in the car. I'll let you know how it works when I take it out in traffic.
Reply #289 on:
May 28, 2016, 01:54:45 PM »
That really looks sweet Tom. That will spur you on to paint now
Reply #290 on:
May 28, 2016, 02:26:11 PM »
Very nice...!!
Reply #291 on:
May 28, 2016, 02:51:03 PM »
Take that fan and toss it ! Those blades straighten out and are useless and create no air draw.
www.derale.com
has the correct fans either steel or steel with aluminum blades that will not bend, that will draw a cloth diaper from 9" away from radiator and hold it too the grill.
If your fan will not draw the cloth from 9" away tooooo the grill at idle 700 rpm then scrap it. They come in various lengths and are less than $50 from derale.
see if I can find a picture.
Last Edit: May 28, 2016, 02:56:14 PM by madmike3435
Reply #292 on:
August 07, 2016, 07:47:21 PM »
Saturday was really hot in the 90's so I decided to take the 33 out for a test. The wife and I went for an ice cream in town and then I decided to "cruise" Elm St. Back when I was younger, this is where we used to spend our weekends cruising. Lots of traffic lights so a good test for the new shroud. Hit almost every red light on the strip and the temp gauge never went over 195°. Looks like the shroud did it's job
Last Edit: September 19, 2017, 07:54:24 PM by TFoch
Reply #293 on:
August 08, 2016, 01:42:28 PM »
Good work, It's always fun to fix something.
Reply #294 on:
September 19, 2017, 07:58:07 PM »
Took a ride recently and turned 5000 miles on the speedo
Reply #295 on:
September 20, 2017, 10:02:24 AM »
Congrats Tom! Drive the wheels off it.
Mean while back at the ranch, i'm still stuck on Zero.
Reply #296 on:
September 20, 2017, 11:29:15 AM »
Way to go Tom! 5,000 fun miles. Bring it to Nevada now that you know it won't let you down.
Yep, No car progress here. Getting ready for winter again. Got a New (to me) tractor. Heck, I've got roadster parts that have been setting in the shop for years and haven't even met each other yet.
Last Edit: September 20, 2017, 11:32:33 AM by sixball
Reply #297 on:
September 20, 2017, 01:09:03 PM »
OK Tom....Now you can call your dealer to schedule your first 5000 mile checkup....
Reply #298 on:
September 22, 2017, 08:48:23 AM »
5,000?! I DON'T HAVE 500!
Reply #299 on:
September 22, 2017, 09:42:36 AM »
I just turned 4,000 on the Buick.
19
20
21
