Author Topic: 1933 Chevy Cabriolet  (Read 153581 times)
Re: 1933 Chevy Cabriolet
« Reply #240 on: May 14, 2015, 09:21:18 AM »
Looks great Tom!!!!
« Reply #241 on: May 14, 2015, 12:48:17 PM »
Thanks guys.  Hope that help FATnLOW.  Let me know if you need any other measurements.
« Reply #242 on: May 14, 2015, 01:50:04 PM »
Thanks Tom, helped out a lot..  I appreciate you help and postings...
« Reply #243 on: May 19, 2015, 08:00:04 PM »
I wanted my alternator to fit down by the drivers side of the block. I tried a standard Delco/GM alternator but no matter how it was positioned it would hit my steering shafts. I got this Denso 55 amp alternator that was small enough to fit where I wanted it. I designed the brackets in CAD and had them machined. This allowed me to get the alternator in the location I wanted.  I did have to trim the inner edge of my front fender but it is still behind the hood when I close it.
« Reply #244 on: May 19, 2015, 09:28:47 PM »
Looks great nice and snug and down out of the way.
« Reply #245 on: May 19, 2015, 09:44:59 PM »
Tom  thats a lot of work looks good  but why could you not put it on the passengers side away from the steering.Prey tell us   vette59jdwl
« Reply #246 on: May 19, 2015, 10:18:10 PM »
Looking at that alternator picture, I don't see how the steering shafts and the coupler will fit onto the rack and pinion without interference .  Picture #6426 shows clearance that another picture made it look like it was trying to go thru the center of the alt.
I used a street and performance of mena ark low mount drivers side bracket and a small GM alternator 100 amp 1 wire.  My mounting and clearance's is much more than whats shown here..  my alt sits about 1/2" away from and tight too the block .  It also is only 3/4" from the frame  due to the starter being larger.  The nippondenso alt appears be real small.  Good idea to store idea for future builds.
« Last Edit: May 19, 2015, 10:22:43 PM by madmike3434 »
« Reply #247 on: May 20, 2015, 07:08:49 AM »
Thought about it but the mechanical fuel pump was in the way.
logride
« Reply #248 on: May 20, 2015, 03:11:12 PM »
Tom, did you make more that one set of brackets? That's a slick setup.
« Reply #249 on: May 20, 2015, 04:13:03 PM »
I had explored that too , moving alt to the pass side , same deal stock FP was in the way. If running electric FP not a problem.
My Street and Performance aluminum bracket fits tight and close to block.  Little snug but works and can get it out easily.
« Reply #250 on: May 20, 2015, 04:22:17 PM »
No I only made one bracket.  I did send the drawings for it to Don (32chevy vett).  He took them to a local water jet shop and had them made out of stainless I believe.  I’d be willing to send the drawings or cad files to you if you’re interested.  I wish I had a water jet or CNC plasma cutter.  I could sell a few :)
« Reply #251 on: October 30, 2015, 09:19:20 PM »
The weather was warmer yesterday so when I got home took the 33 out for a ride.  Got to a stop light and looked at the speedo and took this pic.  3000 miles on the car, nearly 2000 this year and had a blast driving it every mile!  Pretty soon the salt will hit the roads up here in New Hampshire and it'll be time to put it away.  Not a bad thing, I have lots of things to work on.
Ghost I hope you get to take the Buick around the block before the snow falls in Colorado :)
« Reply #252 on: October 30, 2015, 11:40:08 PM »
Tom I put our we truck away lost week was not taking any chances,and this week has been just geourgeous weather for cruizin  vette59jdwl
« Reply #253 on: January 31, 2016, 01:56:16 PM »
It's been a while since I've added to this thread.  I mentioned that I'm going to fabricate a radiator shroud.  I just started it and it'll take a little time to get it right, but here's a little teaser.  I'm going to start with an aluminum cake pan from McMaster Carr.  Stay tuned to see if I can make it work.
« Reply #254 on: January 31, 2016, 01:58:58 PM »
This sounds promising. keep us posted on your progress.
