Author Topic: 1933 Chevy Cabriolet  (Read 152956 times)
Re: 1933 Chevy Cabriolet
« Reply #165 on: May 13, 2014, 08:57:11 PM »
I used Anchor Nuts #GM1021 to hold the fenders on.  These fit and worked well.
« Reply #166 on: May 14, 2014, 06:52:28 AM »
I mounted the rear fenders and used Filling Station #B184 3/16 Beaded Fender Welt.  It's Vinyl and is 1 1/2" wide.  Comes in a 25 foot roll for $15.50.  It fit good but is a little loose around the top of the fender.  I might try a piece of black duct tape on the inside of the welt to tighten it up.
Great info Tom..I have some but could use a 25' roll...that 3/16 diameter is just right.
« Reply #167 on: May 14, 2014, 06:56:41 AM »
How are they installed...did you use existing holes?
« Reply #168 on: May 14, 2014, 07:14:09 AM »
Ed,
They installed just like the originals.  Using the original holes you place them in from the inside of the car.  Then there are two tabs that fold over from the out side of the car to secure them in place.  It makes it real easy to mount the fenders.
« Last Edit: May 14, 2014, 09:27:12 PM by TFoch »
« Reply #169 on: May 14, 2014, 09:36:04 AM »
DID YOU GET THE ANCHOR NUTS DIRECTLY FROM GM OR DID YOU GET THEM FROM AN AFTERMARLKET SUPPLIER.
MIKE
« Reply #170 on: May 14, 2014, 10:20:14 AM »
MIKE
Mike I got the from the Filling Station.  That is their part number.
« Reply #171 on: May 14, 2014, 10:49:30 AM »
found them under MISC FENDER HARDWARE.
  GM-1021 1933---1950passenger fender anchor nut $1.65 each.
There is also a 1925---1932 fender anchor nut GR-179 at $4.50 each
mike lynch..... 8)
« Reply #172 on: May 17, 2014, 08:51:50 AM »
Got the front tires on 33 and got it on the ground.  Here's a couple of pics from in the garage.  I like the way it sits :)
« Reply #173 on: May 17, 2014, 09:15:48 AM »
squats nice, will get a better idea of how low front is when gravel shield goes on and running boards stretch out the side view.
mike lynch    8)
« Reply #174 on: May 17, 2014, 09:41:58 AM »
The tires in the pockets are just right nice and low. ya done good pilgrim....John
« Reply #175 on: May 17, 2014, 10:16:09 AM »
It has a really nice stance Tom, l like it alot.
« Reply #176 on: May 22, 2014, 07:20:28 PM »
While I was working on my front fenders this weekend my Dad, who's a retired sheet metal worker decided to help out and make my battery box cover.  He has all his equipment in my cellar.  He took he measurements and when he came out this is what he had.  We painted it and attached the hinge.  Done and I didn't have to do a thing.
« Reply #177 on: May 22, 2014, 07:49:38 PM »
Tom...Your Dad did great job with that cover. ...Of course you realize that he's now entitled to borrow the car whenever he wants,
 right? ;)
« Reply #178 on: May 22, 2014, 07:56:00 PM »
Moose,
He will get the first ride in the car.  He was born in 1933 so he and the car have something in common.  He's been waiting patiently but hopefully pretty soon.
« Reply #179 on: June 08, 2014, 06:07:26 PM »
Got the car fired up this weekend.  My daughter got the honors of turning the key.  When it first started there was a grinding noise that scared the heck out of me.  It had run a couple of years ago with no problems.  We finally figured out it was the transmission cover hitting the flex plate.  I bought a "universal" plastic one that doesn't fit quite right.  After removing it the car ran great.  Just a couple small leaks I need to fix.  I still have some things to get done before I go to the DMV to get it registered.  I was able to drive it out of the garage, turn it around and drive it back in.  Getting closer!  Here are a couple pics of it while I had it outside.
