Author Topic: 1932 coach build  (Read 235513 times)
Re: 1932 coach build
« Reply #135 on: April 07, 2016, 04:59:54 PM »
I especially like that gauge panel. Is that from another car or did you fabricate that yourself?
« Reply #136 on: April 07, 2016, 07:32:26 PM »
Chopper  I ran across that panel at a car show, a vender must have had it for a while as the package was all faded and dirty. My plan is to have it hydro dipped in a bough walnut pattern.
« Reply #137 on: April 09, 2016, 10:15:01 PM »
Here is a picture of my grille insert in the shell, got that installed today
« Reply #138 on: April 09, 2016, 10:21:28 PM »
I purchased a Vintage Air A/C and Alternator mount and installed that today. Beware that this unit is not set up to be used with a after market intake original equipment only. Vintage Air does not list this anywhere. Took a little modifying and several hours to get it to line up.  If you look to the left of the ac unit you see my cowl vent motor that I talked about in a previous post. Will try and get a better picture.
« Last Edit: April 09, 2016, 10:26:22 PM by 62131 »
« Reply #139 on: April 09, 2016, 10:37:54 PM »
62131.....Which cowl unit did you go with?? and  does it operate ok??   pics if you have them...
Here's a better picture of the cowl vent motor I came up with. If I knew if we could post a short video I show it in operation.
« Reply #140 on: April 10, 2016, 06:27:39 PM »
Nice set up, looks great!
« Reply #141 on: May 11, 2016, 02:06:03 AM »
Thought is was about time I come check out all your guy's builds. Awesome stuff going on here.
Looking at page 1.
I like the wood replacement in steel . Is there any other structure behind the sheet steel ?  Any other pics?
Also did you add any bracing to the fiberglass rear fenders.? I think I may go that route.
« Reply #142 on: May 11, 2016, 11:28:25 AM »
62131 It looks clean and all fits within the confines of a real hood  great  job   vette59jdwl
« Reply #143 on: May 11, 2016, 10:12:35 PM »
I've been spending some quality time in the garage here lately getting a lot of things done. Yesterday I completed my exhaust system, and put my drive shaft in. I have the wiring harness installed and been making termination as I complete sections of the car. I did bump the engine over the other night it won't belong before she will be coming to life :) :)
« Reply #144 on: May 12, 2016, 02:47:51 PM »
62131  Summer is upon us Its time to make a positive difference  sounds like you have your shi#! together going to be a nice ride  can not wait to see it rolling  congrats  vette59jdwl
« Reply #145 on: May 12, 2016, 05:10:51 PM »
Hey vette59jdwl you still interested in the hood? I just have not gotten it weighed to check the freight, I have been putting a penetrant on the hinge pins so that I can take it apart to make the package smaller.
« Reply #146 on: May 13, 2016, 09:10:15 PM »
 I have put more stuff on mine and i cant get it to budge so good luck with that one  OH by the way please send a pic or two to lave@cogeco.ca  thanks  vette59jdwl
« Reply #147 on: May 13, 2016, 09:36:56 PM »
oh its moving on the pins, just trying to get it were I can remove them easily
« Reply #148 on: May 13, 2016, 09:49:55 PM »
Vette,, are you trying to remove the pins from the hood panels????  Mine  were really  tight..what I did was sprayed  with them down with a penetrate( WD 40  or what ever you use)  and let the set  for 1-2 hrs... then took my propane torch and  heated the  pins and pin clamps   then let it  set over night ....then repeated this process again..and then took a drift rod( same size as the pin rod) and hammered the pin out until I was able to get vice grips  on the  pin... then hammered the vice grips and sprayed the pin as it was moving...this worked for me
« Reply #149 on: May 14, 2016, 08:16:59 AM »
That's pretty much how I did it except without the heat
