Author Topic: 1932 coach build  (Read 241412 times)
Re: 1932 coach build
« Reply #90 on: April 30, 2015, 07:35:34 AM »
Nice..wish I was in that stage!
« Reply #91 on: April 30, 2015, 10:50:18 AM »
You and me both Ed!
62131 that's looking smooth.  ;)
« Reply #92 on: April 30, 2015, 07:33:45 PM »
62131...looking good ..trying to get to that stage myself, but it's been a heck of a job....
« Reply #93 on: April 30, 2015, 08:53:05 PM »
I thought I might post these as this is what I did a couple nights ago. This is my second coat of gray high build primer after blocking the first coat. Thought I might just put it together and drive it in primer to work out any problems it might have.
« Last Edit: April 30, 2015, 08:56:16 PM by 62131 »
« Reply #94 on: April 30, 2015, 10:13:23 PM »
That is looking really nice and smooth. You got to be excited about your progress.  8)
« Reply #95 on: May 14, 2015, 04:44:45 PM »
Attended the Street Rod Nationals in Knoxville week before last and picked up a chrome brake booster and master cylinder, can't wait to get it installed to see how its going to look
« Last Edit: May 14, 2015, 09:21:01 PM by 62131 »
« Reply #96 on: June 27, 2015, 09:18:54 AM »
Here's a few pictures of the assembly. just trying to bring everything up to date here,
« Reply #97 on: June 27, 2015, 09:23:43 AM »
Here's a few more
« Reply #98 on: June 27, 2015, 11:43:11 AM »
Look'n good there.  ;)
« Reply #99 on: June 27, 2015, 02:27:06 PM »
LOOKING REALLY GOOD....NICE TO SEE  SOMETHING COME TOGETHER.....CONTINUE THE GOOD WORK
« Reply #100 on: June 27, 2015, 03:51:06 PM »
I like what I see..Brings back memories..Keep um coming!!!
« Reply #101 on: July 12, 2015, 07:29:57 PM »
I finally came up with the ideal how to do my hood. The hinge on the passenger side was rusted away so I cut the remainder of the loops off on both the driver and passenger side. Bent a piece of metal to weld to the top of the side panels. Took some 3/4" tubing milled down some 5/8" key stock so that it would slide thru the tubing.  Then I cut the tubing to length, milled a 1" long slot in one end, inserted the key stock in the tubing drilled a tapped a hole in the center of the key stock and held it in place with a button head screw. Made bracket to attach the sq. tubing to the firewall and welded a bracket to the key stock and attached that to the grill shell.  Did this for both top and bottom on both sides. Now I can loosen the screws and adjust the gap on my hood panels by moving my grill shell.
« Reply #102 on: July 12, 2015, 07:35:42 PM »
Here's a few more. I made adjustable brackets for the bottom so that I can move the hood on and out. I'll have toke some pictures of those.
« Reply #103 on: July 12, 2015, 07:42:28 PM »
Bracing the roof. Made some 14ga. angles and attached them to the roof panel with seam sealer for movement, going to tack weld to bracing.
« Last Edit: July 12, 2015, 07:45:59 PM by 62131 »
« Reply #104 on: July 12, 2015, 08:06:09 PM »
Going to follow this post when you get pics ..Thanks  for posting
