Author Topic: 32' Steering box options  (Read 4774 times)
Re: 32' Steering box options
« Reply #15 on: February 19, 2016, 08:11:05 PM »
Ghost. I may have to connect 2   D-shafts to the box. What did you use or what can I use to change the angle (pivot point).
I used a double universal joint from the box. I did have to use 2 heim joints on my shafts to keep everything solid and not let it flip around. The only reason I had to get so creative was because of those >:( damn headers
« Last Edit: February 19, 2016, 08:40:51 PM by ghost28 »
« Reply #16 on: February 20, 2016, 11:12:40 AM »
Cool. Thank you. Now I got a better idea of what I need to do once the box is mounted.  8)
« Reply #17 on: June 08, 2016, 07:50:52 PM »
Ghost,  I've been looking at your pic #2 .  I guess the drag link dosent have to go directly over the tierod. ???
Cause my Pittman arm bolt hole would be off an inch, compared to the tie rod.
« Last Edit: June 10, 2016, 01:44:11 PM by Rattiac »
« Reply #18 on: June 10, 2016, 01:52:33 PM »
I was looking at the Borgenson website and it said....
Any car over 2500lbs should be using a Saginaw 525 box and NOT a Vega box.
Wished I would have seen this info earlier. Just when you think you've done your research.
What do your guy's cars weigh that are using Vega boxes????
My guess is a Saginaw would be too big to fit where I needed it anyway.
« Reply #19 on: June 10, 2016, 11:21:42 PM »
You will be fine. I have used them under heavy Hemi cars and a coule of 2900 lb plus cars with no problems.
