Miscellaneous => Members Builds - Stocker -Streetrod - Ratrod - LowRider => Topic started by: mixerman on March 29, 2023, 07:38:12 PM
Title: 33 Bowtie build
Post by: mixerman on March 29, 2023, 07:38:12 PM
I aquired this semi-basket case back in July 2021. Restored a lot of cars but never a 30's model, and did I have a lot to learn. Here is some pics of when I got her to the shop.
Title: Re: 33 Bowtie build
Post by: FATnLOW on March 29, 2023, 07:58:22 PM
A good body on the'33 ...enjoy your build....
Post by: EDNY on March 29, 2023, 10:13:53 PM
Looks like you have a lot of good metal to work with.
Post by: 62131 on March 30, 2023, 07:15:38 AM
You have a nice starting piece, is the wood in good shape? or are you going to remove and replace with steel?
Post by: mixerman on March 30, 2023, 04:49:27 PM
All of the wood has been replaced with steel, and has been channeled 4"
Post by: chopper526 on March 30, 2023, 11:27:33 PM
Looks like you have a nice foundation. I am a definite fan of swapping out wood for steel. Good luck, keep the pictures coming.
Post by: Essex_29 on March 31, 2023, 03:42:55 AM
Great looking coupe you've got there, mixerman
Looks to be in good shape too. Post pics as you go, it's always nice to se how projects
go forward and evolve.
Are you planning on running fenders?
Post by: mixerman on April 01, 2023, 12:25:32 PM
Fenders....for now no...maybe in a couple of years when I need something different I'll put on the fenders and have a new ride.
Post by: Essex_29 on April 01, 2023, 05:50:54 PM
Good plan.
I made my last rod fenderless, and this time I'm going for fully fendered. On the other
hand, I guess I can remove the fenders later and get a new ride kinda the same way.
Post by: TFoch on April 03, 2023, 07:13:50 AM
Nice start on your 33!  Keep up the good work!
Post by: mixerman on April 03, 2023, 05:45:23 PM
Here's the start of the radiator fan shroud.
Pic (1)
I had to refine my 3D model to show the bend marks to get the flat pattern to come out right.
And my newly fab'd steel work table.
Pic (2)
Made a card board templete to make sure the pattern was some what close. This is just half of the shroud.
Pic (3)
And another shot of the radiator shell support bracket I had to make cause of another missing part.
Post by: Essex_29 on April 04, 2023, 09:49:58 AM
Good work on the radiator fan shroud!
That's a very neat way to come up with that shape by just bending two pieces.
 I'd like to see how you set it up in a bender/break, or maybe you'll have to bend
it by hand, which would probably work with the 19 gauge sheet steel I work
with the most.
The radiator bracket looks good too.
Post by: mixerman on April 05, 2023, 05:58:46 PM
with the most.
pic 1)Here's my high dollar press break, it worked great for what it is.
pic 2 & 3) All formed up
pic 4) Tack welded to work table for weld up
Post by: TFoch on April 05, 2023, 07:25:29 PM
Looks great, nice work!  Love the "high tech" equipment!
Post by: sammons on April 06, 2023, 05:55:18 PM
Looks good! I enjoy watching how others fab their parts. Might just find that better idea or short cut😁
For decades we didn't have a metal brake. Dad had a beefy work bench he topped with true dimenson 2"x 6" old reclaimed hard yellow pine, it was gapped at 1/16". It would take up to a 3' length any depth, but you would be limited to 2" depth if you needed to brake longer pieces. He had deep throat vise-grips welded to 6" x 2" x 1/8" stap steel for bending. Just mark, stick down in crack and brake it over. I put a 4" angle iron edge on the bench to iron out with a body hammer to get a real sharp/crisp bend.
  Sure was easier when i bought a real metal brake😁
Post by: 62131 on April 06, 2023, 06:47:14 PM
nice work it looks better than the flat ones you can purchase.
Post by: Essex_29 on April 10, 2023, 12:53:02 PM
That radiator shroud came out really good! The result is looking great.
Post by: mixerman on April 13, 2023, 08:00:39 PM
I'm waiting on paint that had to order for finishing up the radiator grill shell and fan shroud, I decided to get another one of my heavy pices of equipment on wheels.
Pic 1) Somewhat build related with the 33 in the back ground is of my air compressor with it's new wheel cart.
Pic 2) close up view of the roller cart
Pic 3) Another view of the off set to keep the compressor low to the ground.
Post by: mixerman on June 07, 2023, 06:20:24 PM
Had to build a fuel tank for the 33, one of many items that didn't come with the purchase.
Only had 5 leaks, I was expecting more.
Post by: TFoch on June 07, 2023, 07:09:33 PM
Very nice work!
Post by: chopper526 on June 09, 2023, 11:22:49 AM
That tank is nice! I wouldn't think to try it.
Post by: 62131 on June 10, 2023, 07:24:00 AM
Nice job, what's the capacity?
Post by: Essex_29 on June 12, 2023, 03:55:57 PM
What material is the tank made from?
I'd need to build a tank for my Buick too, and have been thinking of making it from normal
19 gauge steel sheet metal, since I haven't ever welded aluminum before.
Post by: mixerman on June 15, 2023, 06:53:51 PM
Tank size is right at 14 gallons
16/ga. cold roll sheet steel
I was going to do either aluminum or stainless, but cost made me go the steel route.
Post by: mixerman on June 26, 2023, 06:10:17 PM
Got around to getting my gauges installed, but first I had to fix the butcher job that was done to the actual dash.
pic # 1 before
pic # 2 after
Gauges in gauge panel
pic# 3 & 4
Post by: sixball on June 26, 2023, 10:29:03 PM
Those are nice gauges. Good repair job.
Post by: sammons on June 27, 2023, 06:54:58 PM
So many dashes got butchered up thru the years for gauges etc. Nice repair, and good looking gauges. Those look like the style i got for mine, i used Autometer classic Hot Rods. Are yours Stewart Warner?
Post by: mixerman on June 30, 2023, 09:18:28 AM
Thanks,
Thanks,
Stewart Warner...yes they are.
Post by: Essex_29 on July 04, 2023, 03:58:45 PM
Nice sheet metal work!
Post by: TFoch on July 04, 2023, 06:25:43 PM
Lookin' good!  I have a CAD drawing of the insert (mine is made from black walnut) if you're interested.
Post by: Essex_29 on July 28, 2023, 02:43:59 PM
Good work on unbutchering the dash.
The tank too, it looks very good and sturdy. Thank you for the inspiration, I sat drawing up plans for a
tank for my Buick project the other night.
